MultiECUScan 1.2R1... ;-)
alfreire
Incluye Loader... ;D espero no infringir ninguna norma... ::)
Descarga directa:
Insertar CODE, HTML o PHP:
https://www.sugarsync.com/pf/D6131127_626_407487736?directDownload=true
SaluII... ;-)
alfreire
Arkangel0770 dijo:
Buena broma!! .... Pero como se hace para instalarlo ????
Lo instalas,copias el Loader en el directorio del programa, luego ejecutas el Loader y listo...
SaluII... ;-)
alfreire
sergio156jtd dijo:
Grácias! Que diferencia hay con el FES? Aparte de poder mirar Suzuki?
La verdad es que no lo sé... voy a ver si encuentro algo y os digo...
SaluII... ;-)
p.d.: a ver si esto es lo que querías...
15/12/2012 - MULTIECUSCAN 1.2
- Added support for WiFi interfaces (ELM327, OBD, OBDKey)
- Added possibility to select a parameter for the X axis of a 2D graph
- Added 16x16 map generation based on the data recorded from vehicle. Please note that this function uses interpolated data and may not be accurate!
- Added Cruise control activation function for the newer Grande Punto (>2008) in CAN Setup/PROXI Alignment
- Improved support for Magneti Marelli IAW 4AF/4EF/59F/5AF EOBD Injection
- Fixed incorrect parameter readings for TRW Electric Power Steering (3) (Stilo, Bravo, Idea, Delta, Musa)
- Fixed incorrect parameter readings for Bosch MSA 11 Diesel Injection (2.4) (Marea, Lancia K)
- Support for Bosch Motronic M1.7 Injection (Croma '92, 155, 164, Thema '92) (Full support)
- Support for Magneti Marelli IAW 7GF Injection (Idea, Linea, Uno 2010)
- Support for Delphi Electric Steering (Ypsilon 2011)
- Support for Instrument Panel Continental (Ypsilon 2011) (Info and DTC only)
- Support for Instrument Panel Marelli (Ducato 250 facelift) (Info and DTC only)
- Support for Instrument Panel/Body Computer Continental (Uno 2010) (Info and DTC only)
- Support for DTC Details of Bosch Motronic Me7.3.1 EOBD Injection
- Support for DTC Details of Bosch Motronic Me7.3.1 EOBD Injection (1 lambda)
- Support for DTC Details of Hitachi MPI injection (EOBD)
- Support for DTC Details of Magneti Marelli IAW 4AF/4EF/59F/5AF EOBD Injection
- Support for DTC Details of Bosch Motronic ME 3.1 EOBD (2.0, 2.4)
- Support for DTC Details of Bosch Motronic ME 3.1 EOBD (3.0 V6)
- Support for DTC Details of Bosch Motronic ME7.3H4 EOBD Injection
- Support for DTC Details of Bosch Motronic ME7.3H4M EOBD Injection
- Support for DTC Details of Magneti Marelli IAW 4SF Injection
- Support for DTC Details of Magneti Marelli IAW 5SF CF4/EOBD Injection
- Support for DTC Details of Bosch Motronic Me7.9.10 CF5/EOBD Injection (1.4)
19/10/2012 - FESmobile 2.1
- Updated with all vehicles/modules from Multiecuscan 1.1
- Added multiplexing support for CANtieCAR interfaces
- Added LOG file generation
- Added Min/Max values for graph data
- Added "Abort" functionality during execution of actuators/adjustments
- Added support for some "Adjustments" like Oil Reset and Service Reset
- Fixed bugs which may cause hang or crash
- Fixed bug with registration form size on some devices
- Fixed bug which causes "Invalid ISO" code to be incorrectly reported on some modules
11/10/2012 - MULTIECUSCAN 1.1
- Improved SCAN function
- Added support for OBD-Direct/Protect interface
- Added possibility to change Sevice Distance (on almost all vehicles) and Service Period (on some vehicles) in Service Interval Reset modules
- Added Logistic Mode control for Panda, Croma and 159 Body Computers
- Added parameters for injection quantity, time, advance of all 5 injections in some multijet engines
- Added the generation and export of CSV file with engine parameters during DPF regeneration
- Support for Marelli climate control (Stilo, Bravo) (Full support)
- Support for Marelli 8DF CF5/EOBD Diesel Injection (1.3) (Panda, Idea, Ypsilon, Musa)
- Support for Bosch Motronic ML4.1 Injection (GTV, Spider, 164)
- Support for Bosch Monomotronic MA1.7 Injection (Fiorino, Tempra, Tipo, Uno, Delta, Y10)
- Support for Magneti Marelli IAW 4GF BI-Power Injection (Multipla)
- Support for Magneti Marelli IAW 4GF BLU-Power Injection (Multipla, Marea)
- Support for Driver's Door G.E. PROCOND (Brera)
- Support for Passenger's Door G.E. PROCOND (Brera)
- Support for Driver's Seat LEAR (Giulietta) (Info and DTC only)
- Support for Passenger's Seat LEAR (Giulietta) (Info and DTC only)
- Support for DTC Details of Bosch Motronic MED7.11 EOBD Injection
- Support for DTC Details of Bosch Motronic MeD7.6.1 CF4/EOBD Injection
- Support for DTC Details of Bosch Motronic MeD7.6.2 CF4/EOBD Injection
- Support for DTC Details of Bosch Motronic MeD17.3.1 CF5/EOBD Injection
- Support for DTC Details of Marelli 6JF EOBD Diesel Injection
- Support for DTC Details of Bosch EDC16C39 CF5/EOBD Diesel Injection
08/08/2012 - MULTIECUSCAN 1.0
- Software is now called MULTIECUSCAN
- Added support for SUZUKI SX4
- Restructured vehicle database
- Added "priority" for parameters when recording data
- Added "Torque sensor calibration" for Delphi Electric Steering (500, Grande Punto, Punto Evo, Mito)
- Support for Marelli/Hella climate control (Lybra)
- Support for Magneti Marelli IAW 4AF/4EF GAS Injection (Multipla Bipower, Doblo Bipower) (Full support)
- Support for Magneti Marelli IAW 5AF GAS Injection (Punto Bipower, Panda Bipower) (Full support)
- Support for Magneti Marelli IAW 5SF CF4/EOBD Injection (Stilo, Palio, Linea, Doblo, Ypsilon, Musa) (Full support)
- Support for Magneti Marelli IAW 4SF Injection (Palio, Linea) (Full support)
- Support for Landi Renzo LC02 LPG Injection (Bravo, Punto, Grande Punto, Punto Evo, Panda, Mito, Ypsilon)
- Support for Metatron 6A0/EOBD CNG Injection (Punto Bipower, Panda Bipower, Doblo Bipower)
- Support for Metatron 6A0 CNG Injection (Punto Bipower, Doblo Bipower)
- Support for Metatron 5D0/EOBD CNG Injection (Multipla Bipower)
- Support for Driver's Seat LEAR (Stilo, Croma, Bravo, 159, Brera, Delta) (Info and DTC only)
- Support for Passenger's Seat LEAR (Stilo, Croma, Bravo, 159, Brera, Delta) (Info and DTC only)
sergio156jtd
Alfa 156 2.4 jtd 150 cv casi ná
Esa comparativa es de "multiscan anteriores" Pero antes de éstos está el FES (FiatEcuScan). Lo digo porque a simple vista lo veo todo igual, ojo! que no lo he provado en el coche..
alfreire
Archivo cambiado a formato *.RAR, ya que algunos compañeros tenían problemas con el formato *.7z de 7-zip... ;D
SaluII... ;-)
kikio
Thanks ;D ;D
cocogalilea
me funciono la primera vez, cambie el idioma a español,lo volvi a reiniciar y me pone programa gratuito, el loader lo tengo en la misma carpeta y lo ejecuto como admin, no se que pasa.
Ya he probado a reinstalarlo, borrando todas las carpetas y posibles restos del programa y nada
Una manita?? ;D
sedicivalvole
Está caído el enlace!
